Need wot switch + controller's tps switch?
Old May 3, 2008 | 01:46 AM
pHEnomIC's Avatar
Default Need wot switch + controller's tps switch?
My nitrous kit came with a WOT sensor. My controller, p series gauge also has this feature. It connects to the pcm for both rpm and tps (window + progressive+ wot)
Should I install the physical sensor in addition to the electronic control or is it fine?
Old May 3, 2008 | 10:09 AM
Alt's Avatar
Alt
You should be fine without the physical sensor and with it as well. You're only throwing another safety into the circuit. If you don't like the look of a WOT switch mounted to the TB then you already have a safety in place to ensure that you're already at a WOT condition, so why mount one?
You would be okay going both ways.
