Quick bottle pressure question
Old May 4, 2008 | 06:00 PM
ScreaminBird99's Avatar
Default Quick bottle pressure question
ok so when the bottle was filled the bottle heater would warm up to 900-950 in a heart beat, im wondering if te bottle may be empty, because 1) the pressure wont go above 600 and 2) when i purge it wont make te cloud like it used to, so im thinking there maybe oxygen, but no nitrous....what do you guys think?
Old May 4, 2008 | 06:21 PM
MeanWS6's Avatar
1. full bottles generally heat up quicker
2. weigh the bottle and compare with the sticker stating the empty/full weights --best way--
3. hot or humid days you wont always see the spray plum on a purge
4. --last resort-- hold the bottle AWAY from you horizontally, with the opening facing up, now tilt it down 45 deg and crack it open a bit, if you dont see spray it's all air coming out first
give that a whirl and let us know; then we either solved ur prob or we can start from there and trace back
good luck
Old May 4, 2008 | 06:25 PM
jmill96Z's Avatar
It's usually opposite for me. When it's about empty I can hardly get any pressure out of it
