Line leangth from noids to plate F16" N24"???
Old May 5, 2008 | 12:21 PM
SY732's Avatar
Default Line leangth from noids to plate F16" N24"???
I just installed a progressive controller and my AF is fluctuating too much for my liking so if I have a 16" line with two bends in it from the Fuel Noid to the plate how long should the N20 line be to try and get them to hit plate at the same time 24" ? or as optimally as possible?
Old May 6, 2008 | 09:03 AM
Chris@NitroDaves
Guest
Posts: n/a
I'd Suggest going to a 2 1/2Ft to 3Ft hose on the nitrous side. That should get you taken care of but i'm not 100% sure because there are no calculations to determine how long you will need.
-Chris
Old May 6, 2008 | 11:22 AM
SY732's Avatar
Thanks Chris I tried the 16/24 combo large improvement on 75 and 100 shot
I will test it with the 125 shot b4 adding more.
Then I am sending you my lines for new black fittings
