Please help newbie wants to run nitrous!!!
First I have a 02 Trans am 6spd...with Pacesetter Lt's...TSP Torquer V.3 cam...TSP Y......i want to run nitrous and have never messed with it at all......im not looking to break any track records i just want to have a fast street car...just hoping someone would help me out on what kind of system to get wet or dry...and how big of a shot i could use without putting the engine in danger....any advice would be GREATLY appreciated
Lots of info on the forum.
Research the different systems (Dry Nozzle, Wet Nozzle, Plates, Direct Port etc...) When you pick the style your interested in, call the Vendors, ie Dynotune, Nitrous Outlet, and HSW. Tell them your goals and what your interested in, then listen to what they have to say, and then pick your kit.
In addition to a base kit, consider a heater, purge, colder Plugs, and a window switch.
also i found a used system and it has 3 jets dont say what size....just says a 20hp,40hp,and 50hp...it is a NOS system but was also curious if i bought this system am i stuck with only using those 3 jets or can i buy different ones to hopefully get at lease 100hp
