Need Advice
http://www.nitrousoutlet.com/catalog...roduct_id=2891
Also along with the system i'd also get a window switch http://www.nitrousoutlet.com/catalog...roduct_id=2885 and a FPSS http://www.nitrousoutlet.com/catalog...roduct_id=2553 . This will net you 2 of the major safety items needed to have a safe setup.
-Chris
A heater is great to have to keep your pressure where it needs to be, our fully automatic heater will run you $99. I would also add a WIndow Switchg - 2 choices depending on the features you need:
http://www.dynotunenitrous.com/store...?idproduct=194
or
http://www.dynotunenitrous.com/store...?idproduct=288
FOr safety this is what I would recommend:
http://www.dynotunenitrous.com/store...p?idproduct=67
A FPSS is OK but does not provide you the safety you will need 90+ % of the time --
Did you know that you can run lean, damage your motor and your fuel pressure can still be fine? You can have good pressure but not enough fuel volume your FPSS wont help. If you have a clogged or faulty fuel solenoid the FPSS won’t help. You have a clogged fuel jet the FPSS wont help.
Hope this helps!
Dean
Seems to be a well liked system.
