Cam question
Old May 8, 2008 | 12:01 PM
101mmSBC's Avatar
Default Cam question
What off the shelf cam are you big shot(200+ pills) nitrous guys running? I had a g5x3 on a 114 in the stock motor last year, but this year is a 408 with more spray. I need a hyd roller that will make killer power on spray, or is the g5x3 a decent cam still because of the tight lsa?
Old May 8, 2008 | 01:37 PM
5_02ls1's Avatar
customis your best bet...you want 0 or negative overlap...on the big shots
Old May 8, 2008 | 11:45 PM
101mmSBC's Avatar
I'm planning on a custom cam once I get the AFR 225's for it later in the season. Maybe I should just run the G5x3 until I get the new heads and just do the cam at the same time.
