Want to spray my LE2 Bird...
Old May 8, 2008 | 12:35 PM
DopdBrd's Avatar
Default Want to spray my LE2 Bird...
So I have a 96 Bird with the LE2 kit on it. It puts down over 400 RWHP now and I want to spray a 150 shot on it sometime soon.
I have EVERYTHING hooked up and ready to go, all I need to do is fill the bottles and spray it. It is a Nitrous Works plate kit with a FPSS and a Nitrous Outlet Window Switch and 1st gear lockout.
I have a LM-1 Wideband hooked up to it with a Fuel Pressure gauge so I can monitor the run with everything. Also I can hook up the laptop and log some runs.
Now the car is still the stock bottom end. How much timing should I pull and should I try spraying it or wait until I have it on a dyno?
Old May 8, 2008 | 12:57 PM
daniel6718's Avatar
1 degree per 25 hp
