fogger mounting question
Old May 8, 2008 | 09:24 PM
vipershark11's Avatar
Default fogger mounting question
ok so i dont have an ls1 but its an 89 with the tpi on it. anyways the throttle body has an airfoil in it now. i mounted the nozzle where it could reach and i was wondering if this will create a very uneven distribution by putting it here or if itll be fine. my theory is that air is rushing in so fast along with it and the passenger side runners are closer so theyll take a draw from the mixture and the rear driver side runners will get the rest of it which i would assume would be about even but i could be wrong hence why im asking you guys here. also you guys seem to know more about nitrous here than anyone else so thats why its here. BTW ill be running a 100-150 shot.
thats a NOS fogger 2 nozzle.
Old May 8, 2008 | 09:26 PM
also i cant put it in the top or bottom. the bottom is near the belt and the top will hit the hood.
Old May 10, 2008 | 08:20 PM
SSPerformance's Avatar
you will be fine
Old May 13, 2008 | 02:10 PM
5_02ls1's Avatar
looks fine
Old May 13, 2008 | 03:15 PM
wow thanks guys i didnt expect that answer. you guys are always good here thanks again ill share results when i go to the track with it next month.
