Direct Ports and smaller HP shots
Old Aug 7, 2003 | 11:36 PM
bigSS's Avatar
Default Direct Ports and smaller HP shots
Is anyone running a Direct Port setup and running a lower shot, like a 100 or 150 shot? Any problems? I ask because after speaking with Compucar, they mentioned that when you starting running THAT small of a jetting on a direct port even the tiniest forein matter could plug the jets. Any validity to that statement?
Corvette only:
Also, as far as a WOT switch and RPM switch, what are most people running? What about a FPSS, what are you guys using?
Old Aug 8, 2003 | 01:52 AM
CAT3's Avatar
Restricted User
Default Re: Direct Ports and smaller HP shots
Well it makes sense that if someone where to run a kit and no filter that just due to the size of the orifice it could plug easier, but that seems a little "what if" to me. Hell, a little foreign matter can make a solenoid stick open too for that matter.
