propane mixed with Nitrous
So far what I've learned is the ratio is 10:1 for Nitrous to propane. Now to inject this into the motor directly or with the wet shot on the propane (or gas) Should I add a Y fitting (at the nitrous line going into my plate, so both Nitrous and propane are on at same time and injected at same location?) then use the according size jet for the propane?
Maybe use a secondary plate. Or inject the propane after the MAF and spray it in with the incoming air charge?
HELP, I'm tired of chasing faster cars.
Robert
So if I'm getting this right. Forget running all three together at the plate. Run Propane on the gas side, NX on the NX side. Jet both Propane and NX with same size pills/jets?
Change and gap plugs accordingly? I'm running msd coil, wires and 6 A box. Am stepping into retard box as well
By the way I miss the northwest. BC guy here out of Prince Rupert. (Robert56)
I avg on reaction times if i'm racing ; anywhere from .02's to .00's Last time out I ran 5 times. fastest was two 7.86's, one 7.9 and the other two were 7.88 and 7.88. I also watch the track the lights. I'll see where its gripping. I actually stage offset out of other tracks to get fresh vht. Its a combo of many little things. I was running 8.10-8.14's one night; good buddy who could drive ran three times, all around 8.31-8.33. SO its a consistant car, it launches straight and never touch the wheel.
Never sprayed
looking to spray around 75-125. depending on safety
