zex ls1 kit
Old Mar 13, 2010 | 04:05 PM
99FRC's Avatar
Ok, how about some input from someone who has actually done this before. LOL!
I bought the Zex kit because I did a lot of reading on this forum and research and found that it was perfectly acceptable for spraying 100. It was easy to install and had a built in wide open throttle switch. Who gives a **** if it's purple?
In the long run, I ended up up switching out all of my stuff for some high dollar stuff (NX Carbon noids, Nitrous Outlet Trick Window switch, machine gun purge, etc) just because I wanted the best stuff on my car. It wasn't that the Zex stuff didn't do exactly what was advertized or wasn't perfectly ok for spraying 100 or even 150.
If your budget won't allow the expensive stuff, then Zex is just fine. However, you need a window switch and a purge, so factor those in when comparing and planning your install.
Good luck!
Old Mar 13, 2010 | 07:34 PM
danieloneil01's Avatar
Originally Posted by 99BlackTransAm
It is a real easy hook up, But for my wallet im going with HSW wet shot that way i have money left for a window switch and RPM pills
Then ZEX direct port LSX set up for my FAST 92/92 down the road..
a window switch would save your tranny in the long run too.. just my .02
Cold plugs would be safe as well..
How does a window switch save your tranny?
Old Mar 13, 2010 | 07:53 PM
camscam02's Avatar
BTW this thread is from 2008.
