timing LT1
Old May 19, 2008 | 10:35 AM
Burning Rubber's Avatar
Default timing LT1
Is there any way I can retard the timing on my LT1 only when I am using my nitrous? I have a mallory 685 ignition box. I dont want to have my timing retarded all the time. Just when I am spraying.
Old May 20, 2008 | 11:24 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
the 685 only retards timing when it is active.....the retard control wire taps into the 12v signal from the relay to your solenoids. It will only pull timing when the solenoids see power.
