pistons and N2O
Old May 20, 2008 | 06:34 PM
sulli's Avatar
Default pistons and N2O
i am putting a 383 LT1 together that has N2O rails in it that can handle from 150 shot to a 300 shot. i have speed-pro hypereutectic floating pin pistons summit part number TRW-8KH860CP30 and was wondering what would be the recommended shot used on these pistons since they are not forged?
Old May 21, 2008 | 04:02 PM
matai70's Avatar
I would say 150 would be fine. 200 and I think you would be pushing it a bit but just have a good tune.
Old May 21, 2008 | 04:16 PM
landonew's Avatar
If they aren't forged i would assume that they are not any stronger than the stockers, so 150???
Old May 21, 2008 | 04:20 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
I would suggest talking to Speed-Pro directly, they will know best. It will also depend on how the rings are set up.
Old May 21, 2008 | 05:39 PM
sulli's Avatar
i was told that it should take 200 easy with the 11.5-1 compression that it has and the hypereutectic pistons that are in it.... would nitrous based rings have a tighter gap? i know that the top is a molly coated and they are 1/16, 1/16, 3/16.
Old May 21, 2008 | 09:55 PM
5_02ls1's Avatar
ive seen a 2oo shot sprayed on those pistons....
Old May 26, 2008 | 01:11 PM
sulli's Avatar
i was just wondering how the rings would need to be set up beside the normal stagger and design.
Old May 26, 2008 | 01:17 PM
chevyguy7802's Avatar
I would spend the extra bucks and go forged....
Old May 26, 2008 | 03:58 PM
JL ws-6's Avatar
Race your car!
Before the motor is fired, I'd get those pistons out of there and get a good nitrous piston, and sell the ones you have.
You'll thank me later.
Old May 26, 2008 | 08:43 PM
sulli's Avatar
is the only difference in the ones that i have and nitrous pistons are just one is forged? or do i need to look for something different? also while im here does anyone have any good nitrous pistons sitting around?
Old May 26, 2008 | 09:40 PM
car_fixer's Avatar
ring gaps are larger for nitrous, or any power adder for that matter. Those pistons might be ok with 200....untill it detonates, then you have trouble. forged pistons are less fragile and can deal with a little detonation, hypers, on the other hand..well damn near shatter
Old May 27, 2008 | 12:03 AM
firefighting1101's Avatar
yeh be carefull with the pistons. i would surely contact the manufacturer and see what they say.
Old May 27, 2008 | 04:30 AM
JL ws-6's Avatar
Race your car!
Ring gap is different, how far down from the top the first ring is, alot of stuff.
Sucks that they're heavier, but ou need more material in order to withstand abuse. Rebalancing the whole lower end isn't probably something you wanted to do, but if you want to hit it, you really need the right parts.
