Complex wiring question
Old May 23, 2008 | 02:58 PM
allna6's Avatar
Default Complex wiring question
Ok zex apparently cannot help me so I hope some one on here can.
I am trying to hook up my nitrous setup using a zex TPS switch and Zex window switch. I am sure all my connections are correct per the supplied schematic. However I cannot get the switches to click the relay.
This this is what I found out the wire running into the relay from the switch creates a ground when the switch is activated,which it is doing, but when I tested the circuit with my multimeter it only reads 9 volts. If I test any other power to the same ground I get the same voltage. If I test the power on the relay circuit to a known good ground I get 12 volts. So somehow there is a voltage drop coming from the switch. All componenets are new and have just been installed.
Please help me figure this out.
Old May 24, 2008 | 12:41 PM
Robert56's Avatar
Try NO, they sell the Zex stuff, and a couple of the guys really like doing the wiring side of things. Check the sticky for the who to pm.
Robert
Old May 24, 2008 | 01:12 PM
allna6's Avatar
Cool thanks alot I will give them a shot.
I think I have a defective window switch though
