Hit the Limiter A Couple of Times. What To Look For?
Old Jun 4, 2008 | 11:25 AM
1997 Z71's Avatar
Default Hit the Limiter A Couple of Times. What To Look For?
I finished off my clutch at the L.A. Invasion. I got this the LT1 in the 11's. On the 3rd run, the clutch let go. Like an idiot I powered through the gears. Luckily I did not grenade the motor. The oil looks OK.
Guess what I had sitting on my toolbox, but did not have time to install. A Window Switch.
Question is what do I need to look for? Would the spark plugs be able to tell me anything? Any help greatly appreciated.
Old Jun 4, 2008 | 02:16 PM
TARZAN's Avatar
I'd check the plugs, make sure you didn't bend any pushrods, and might even run a compression test, depending on how bad it was.
-Will
