fuel question ????
Old Aug 14, 2003 | 03:08 AM
BLUE01Z-28's Avatar
Default fuel question ????
when i spray my no2 the fuel selinoid will not shut off even when i shut down my system, i dont know why it's doing it. i have to shut my car off to make it stop spraying fuel into my intake ?
thanks
Old Aug 14, 2003 | 08:06 AM
bmbutler's Avatar
Default Re: fuel question ????
Easy....replace your silenoid or get a "rebuild kit" for it. They tend to go out sometimes or if something slipped through your fuel filter and got caught in the silenoid.
BE THANKFUL IT WASN"T YOUR NITROUS SILENOID....KABOOOM!
Old Aug 14, 2003 | 05:35 PM
BLUE01Z-28's Avatar
my kit is brand new
i hope that they will just give me a new one
but thanks bnbutler
Old Aug 14, 2003 | 07:16 PM
Ron@Vengeance's Avatar
Noid is ok, you have the noids wired incorrectly. Are you using an MSD window switch? Recheck your wiring, I had the same problem with the original TNT directions and an MSD switch. Got the revised instructions and it worked flawlessly.
If that doesnt fix your problem, take remove the nut from the noid, dis-assemble, clean "plunger valve" and re-assemble.
Old Aug 15, 2003 | 01:57 PM
BLUE01Z-28's Avatar
thanks
