HSW StandAlone kit, Problems Help!.
Old Jun 10, 2008 | 08:49 PM
OldskoolRcr's Avatar
Default HSW StandAlone kit, Problems Help!.
Recently purchased the HSW Standalone fuel system, I installed it today on one of my 2 camaros, When I bought it they told me I could set the F/P by just turning on the system, I did not have to flow it through a N20 jet since it was a return style Aeromotive Reg. Heres the problem in order to get the 58psi that is needed I have to turn the screw so far into the regulator, there is no way to put the lock nut on, actually it is in the reg about 1/8 inch. And yes it has the correct spring in it. Whats up, am I doing some thing wrong? I would have called HSW but they are closed, and thought someone could help me out. Thanx.
Old Jun 10, 2008 | 09:30 PM
Ok I figured it out, when I bought it I asked which spring was installed and they said the High Pressure, guess what Nope! I changed the springs and 58psi perfectly.
