How to set up my a/f shutoff?
Old Jun 17, 2008 | 12:23 PM
pHEnomIC's Avatar
Default How to set up my a/f shutoff?
I have rich and lean shutoff on my Trick performance P-series gauge. I have it tied to a plx wideband sensor.
I have an 02 ls1 w/ 150 wet kit + torquer v3 cam + all boltons.
I am a bit confused as to how to setup my rich and lean shutoff since there is a difference in the two formulas.
The plx's formula for a/f is 2*Volts + 10 and the Black Series Gauge uses 2*Volts + 9. The thing is, there doesn't really seem to be a total 1 a/f difference between my plx gauge (the one that came with the sensor) and the black series one.
What values should i set my cutoff for lean and rich and how much delay should I put on it? Give me your suggestions and I will tweak them on the gauge so that they actually work as planned.
