How To Take Apart Bottle??
Old Jun 19, 2008 | 07:47 AM
TXZ0603's Avatar
Default How To Take Apart Bottle??
I have a bottle with what I am assuming is a loose siphon tube inside. It clangs around while driving or at even the slightest bump. I turned the bottle upside down and got liquid as well as right side up. So how do I take off the top to fix it??
Old Jun 19, 2008 | 09:16 AM
Wonderbread's Avatar
With a bottle nut on the threads set the bottle on a bench or on the ground using your knee to hold it down. Smack the bottle nut with a hammer so that it is spinning counter clockwise. It should loosen up after one good hit.
Old Jun 19, 2008 | 09:20 AM
TXZ0603's Avatar
Thanks!!! Ill give that a shot tonight
Old Jun 19, 2008 | 10:01 AM
Chris@NitroDaves
Guest
Posts: n/a
Couldn't have said it better.
-Chris
Old Jun 19, 2008 | 10:04 AM
Mikes96z's Avatar
Overfill it then use a torch to raise the bottle pressure when it's over 100 degrees outside.. It'll come apart. Joking btw.
Old Jun 19, 2008 | 10:07 AM
-Chris
Thats probably cause you told me how to do it...lol.
I think maybe this question/answer should be added to the master nitrous FAQ.
