Nitrous Gage reading yellow......
Old Jun 19, 2008 | 07:56 PM
blkramair's Avatar
Default Nitrous Gage reading yellow......
I went to try to test my nitrous for the first time this summer when I turned the **** on the bottle all the way it only read in the yellow!!
I know it should be running between 950 and 1050 psi to work effectively.
i even turned on the bottle warmer and the gage did not move at all to the green!!
Anyone with any ideas on this i would apreciate it...
Old Jun 19, 2008 | 08:41 PM
Beer99C5's Avatar
Should take no more than 20 minutes for the bottle to heat up. Did the heater get hot? Full bottle is usually 600-700 PSI cold (relative to summer )
Old Jun 20, 2008 | 10:04 AM
Chris@NitroDaves
Guest
Posts: n/a
Do you know how long you had the heater on for? Also what did your bottle weigh? It should weigh 24.5lbs if it's full.
-Chris
Old Jun 21, 2008 | 05:59 AM
blkramair's Avatar
I think you may be right I am probably low on the nos.......
Thanks for the replies
