Direct Port braided lines?
Old Jun 24, 2008 | 02:39 PM
LSX-PWR's Avatar
Question Direct Port braided lines?
I have the TNT Direct Port system but I would like to replace the hard line for some braided lines because I heard that the hard lines leak. Where can I find the braided lines?
Old Jun 24, 2008 | 02:48 PM
Robert56's Avatar
Any of the n2o vendors can set you up. I also like braided lines much better.
Robert
Old Jun 24, 2008 | 03:07 PM
Nick@HSW's Avatar
Just jump on our Interactive Hose Maker and you can customize them to fit all your needs.
Nick
Old Jun 24, 2008 | 03:32 PM
Nitro Dave's Nitrous Outlet's Avatar
We have been using braided hoses for years. Hardline will not leak if you have a good flare. Keep in mind with the TNT distribution blocks if you do away with the hardline you are doing away with the support that holds them in place. Unless you build some type of bracket they are going to bounce around.
We custom make hoses to any lenght. Just give us a call if we can help.
Here is a link to some of the directports we have done that may give you some ideas.
http://www.nitrousoutlet.com/installs/index.asp
Dave
Old Jun 24, 2008 | 04:53 PM
LSX-PWR's Avatar
Thanks guys for the info. Now I need to fabricate a bracket for the TNT blocks.
Old Jun 24, 2008 | 05:36 PM
Robert56's Avatar
Check Dave's pics and I have mine in Fquick in sig. You can mount your blocks off the fuel rail as an option, maybe, like HSW did on my intake?
Robert
