Electronic WOT Switch help!!!!!!!!!!!!
Old Jun 29, 2008 | 09:48 PM
cbra-klla's Avatar
Default Electronic WOT Switch help!!!!!!!!!!!!
Just finished up most of my NXL direct port today.. i am having some issues getting the electronic wot switch to kick on properly..it kicks on when i am about 3/4 to being wot....i tried adjusting the set screw on the box till it disengages but it wont...any ideas???
Old Jun 29, 2008 | 10:04 PM
proelky's Avatar
Are you running it off of the PCM wire? If you have the same one I do...It's not adjustable. If sets off of the TPS voltage (increase/decrease). Dumb question, but did you follow the instructions on setting it up?
Old Jun 29, 2008 | 10:11 PM
cbra-klla's Avatar
tapped into the wire on the TPS sensor.....it had directions for adjusting it...my buddy has a different one on his car and we just pulled current off of the same one his did....is there another place to tie into???
Old Jun 30, 2008 | 05:21 AM
860 Performance's Avatar
Is it the new NX TPS box w. autolearn, or the older one with the set screw?
If its the older one, I know you need to turn that thing a lot before it makes a noticable change.
Old Jun 30, 2008 | 06:06 PM
cbra-klla's Avatar
it has the set screw..i bet i turned it 20 revolutions and no change
