Msd Window switch
Old Jun 29, 2008 | 10:33 PM
gsxr1k2's Avatar
Default Msd Window switch
Well I just installed my nx wet kit and I can't get my window switch to activate the system. I've bypassed my fpss and still no results and finally bypassed the window switch and the system would finally activate. I've double checked the wiring and found no problems. I was wondering if the tach signal is to weak to activate the switch. I've spliced into ecm for the tach wire. Any help would be greatly appreciated...
Old Jun 29, 2008 | 10:39 PM
cbra-klla's Avatar
is it the digital box??
Old Jun 29, 2008 | 10:58 PM
jmill96Z's Avatar
I had the same problem all of last year with mine. Make sure if it's the digital to put it in 4 cyl mode. If not, I would go with a different window switch. IMHO those digital MSD's are junk unless you can pull the signal from a box.
Old Jun 30, 2008 | 12:44 AM
SuperSlow02's Avatar
Yea...I was having problems getting mine to work right..had it set on 1cyl like the directions say but as jmill said, set it to 4cyl mode. Works like a charm now
Old Jun 30, 2008 | 06:36 PM
16again's Avatar
I had the same problem with the MSD box. IMHO it's junk. Get yourself one of these bad boys. Awesome and easy install.
PN TPP-00011 Dual Window Switch
http://www.trickperformanceproducts.com/tpp_00011.htm
http://www.trickperformanceproducts....ndowswitch.htm
Old Jun 30, 2008 | 06:43 PM
cbra-klla's Avatar
i havent had any problems with my switch..i love it
Old Jun 30, 2008 | 10:20 PM
gsxr1k2's Avatar
ya i'll have to look into somethin else.......
