need help wiring efilive 2step with nitrous
I also have efi live cos3 with the 2step. The way that works is a wire from pinout 56 of the pcm just needs grounded to turn on the 2 step.
Currently I have the 2step ran to a momentary switch that acts as a system on/off. Then it goes to a relay that ties into the brake light switch. The way it works, is if i press the brakes and have the momentary switch on the pcm will be grounded until i release the breaks or release the momentary switch. That way I can launch the car off the foot brake and then turn off the system by releasing the momentary switch when I feel like it after the launch, but before I hit the brakes again.
What I need help on is getting the nitrous system tied into the 2step system. I cant think of how to do it. Every way I see in diagrams would send 12v to the pcm pin 56 and i dont want to do that.
help!
