First N2O Shot
Old Jul 10, 2008 | 09:25 PM
tatasta's Avatar
Default First N2O Shot
As said, just finishing installing my wet kit. Got the FPSS, WS, NX blanket (it is bad ***!), Cold Fusion's new opener (not solenoid), Nitrous Outlet heater, purge w/ 860 "V" spray purge, Nitrous Outlet switch panel, 860 spare tire mount. Nice ****. Anyway I have a wideband and Predator plus tuning help from Rick at STS which is dialed in N/A.
Question: Am I better off starting off all the way down at 35 hp shots for tuning and work my way up or start at 100? My ultimate goal is a 125 shot and that's where I will stay until a forged stroker 408 this winter. I can adjust my timing and fuel on my own to a certain extent.
Thanks
Old Jul 10, 2008 | 09:34 PM
Mike@HSW's Avatar
nope, jet it for the 125 shot or 100 if you plan on using that for now. If you use the right fuel jet for a 100 shot you should be just about right on. if you want to richen up the tune or lean it out just swap out fuel jets.
Old Jul 10, 2008 | 09:37 PM
waterbug1999's Avatar
What Mike said... Just make sure your N/A tune is good, then just use the right jets and youll be fine. Just make sure you take some timing out of coarse.
Old Jul 10, 2008 | 09:51 PM
SuperSlow02's Avatar
we just did a wideband tune on my car yesterday for the nitrous. N/A tune would have been good enough, but i didnt want to chance it. I just went with the kill pills(150). As mike said, go with that you plan to spray and tune it to that.
