Does this look alright?
Im having a little bit of trouble figuring out what to do. What I want is not to use a WOT Switch if possible and run of of the TPS Signal. Will this work. If not can someone correct it for me?
Yes sir you can run it straight off the TPS. Instead of running the blue wire from the window switch to the WOT switch, you want to run the blue wire from the WS to the blue wire on the TPS. That is how I did mine and it works flawlessly.
