Zex window switch programming !!!
Old Jul 17, 2008 | 03:13 PM
stevegrizzle's Avatar
Default Zex window switch programming !!!
I tried searching, really qucik question.....
In step 1 where you set it to how many cyl to read on the tach wire, do I input 00(for coil on plug) or 04( for 4 cyl)?
Old Jul 17, 2008 | 03:59 PM
I figured it out for myself, If you are using the tach signal from the plug on the head ---->> Then you use 00. If you use the input near the ECU you use 04.
