LSX 440 Cubic inch
It sounds as if you car, in the words of Jake and Elwood: "Is on a mission from God" with all those sevens!
7.77 at 177
http://videos.streetfire.net/video/N...UTE_173205.htm
Robin
To be sure the chassis has several advantages over a rules limited Drag Radial Stock Suspension car ...F Body or Nova.
Our current 60' is worse than many current drag radial cars. So yes we will improve there.
Our Liberty transmission is much better than any automatic. We can kep our RPM band to a higher average than any automatic, we have 5 gears!
We currently have a big tire on the car, we are not faced with the need to kill power to get the car down the track.
Did I say the car is as areo as a brick?
It isn't possible to compare restricted heads up race cars against one another. I suggest that you compare the power they make given the rules they race under.
It's an LSX, that is the bottom line.
BTW, we are restricted to a .046 jet in NPS. We still have some more jet to go before we get to that limit
Robin
It was at the LSX Shootout last year but we didn't spray it. We were just shaking it out.
It will be at the LSX Shootout trying to give the big blocks a run for the money in NPS.
The turbo cars remain very tough. They will be going .40s or faster by October. This engine in a legal chassis and a legal transmission as well as 2 more kits would be behind the turbo cars.........
BTW, our 60' needs work, we are leaving 2 tenths in the 60'
Robin
LSX
LSX
We need to take a bit more clutch out at the launch. The car picks up the front wheels on the 1-2 gear shift. You can see in the vid that I correct a little bit from the car going a little left. The car is very stable at 179 but there is way too much air getting under the hood. We have to run stock open grilles per the rules. We are installing a spoiler/valance under the front bumper to reduce the amount of air that goes under the car. To get the car lower would require a lot of work. We run a stock stub and a rectangular frame rails in the rear.
Once we get the clutch close it shouldn't pick up the wheels on the shift.
The car is currently at Kirkman Composites getting some weight reduction. It's on their flat plate getting the suspension laser checked for alignment. We want to be sure that the housing is sqaure in the chassis.
Good read on the video!
Robin
Just wondering why you guys chose the NOS brand fogger over NX, Speedtech, wilsons, etc. ? Sponsorship or what? I just heard their stuff doesn't flow/make as much power as other brands. Not sure if that is true or not, but i was just curious.
Holley/NOS has a very good working relationship with GM Performance Parts.
I have heard or hear some of the same things that you have. As companys evolve there can be ups and downs. Some of the other companies have established themselves as players in the Nitrous market. The company NOS as you know has ben around for a long time. The leader in most industry tends to become the target of others wanting to increase their market share.
After working with the guys at NOS for a couple of years I am convinced they are as competitive as some of the other companies that you mention. There are many ways to make power with Nitrous. There are a lot of different tuning ideas. We have seen serious power from the NOS Fogger that we are using. Distribution is good and we are not hurting parts.
We work with Monte Smith as our Nitrous Tuner. Monte has been around for a long time and really knows his stuff.
I am VERY pleased with the results of my NOS system.
Robin
While testing at Reynolds Georgia earlier this year we ran a 8.58 at 152. That was with a 1.31 60' and a bog out of the hole. We later found the reason the nitrous would not actvate. While on the dyno the guys changed the throttle linkage. When it was installed in the car and the hood scoop installed it would hit the side of the scoop and prevented us from hitting WOT and activating the Nitrous. We had not intended to run on motor but after it launched I ran it out. The DA that day was below sea level and the tune was lean.
Robin
