Nitrous Fuel Pressure issues..
Old Aug 4, 2008 | 01:10 AM
Meen95z's Avatar
Question Nitrous Fuel Pressure issues..
I noticed a problem tonight with my fuel pressure when nitrous is on.. I went to just run the line dry of nitrous after I shut the bottle off and my fuel pressure went from 42ish to 25-30ish when I was running nitrous.. I had a 1/4 tank of gas, the vacuum line to the regulator is plugged so its max fuel pressure all the time.. Newer fuel Filter and I have a Granatelli 255 lph pump which is a few years old.. Also the voltage in the car is 10.5-11.2 volts due to the underdrive pulley.. Any ideas where to start? Thanks
Old Aug 4, 2008 | 08:45 AM
JoeyGC5's Avatar
Get the voltage back up with an overdrive pulley on the alt. Voltage that low doesn't help anything in the car.
