need some wiring help
coming out of the end panel. It is connected to ground when the switch is active, and has
a maximum current rating of 10 amps. NOTE: The RPM range for this switch is 1000 to
12, 8000 and the off RPM (mode 6) must be at least 100 RPM higher than the on RPM
(mode 5).
So, yes, it is the ground for your relay. Don't use it on the 30/87 pin circuit. It's for the 85/86 side.
