Nitrous Max questions
Old Aug 19, 2008 | 03:23 PM
2000whitec5's Avatar
Default Nitrous Max questions
A few quick questions
How low of an RPM can I have it come on at ?
Some backround 2000 Corvette Head cam car with a 150 Wet shot + boost a pump and a Spray tune. Run on 93 Pump gas and Torco
So far best has been 10.08 @ 137.00 turning on at 4000 RPM in 1st gear and off at 7000 RPM
Want to go 9's
Thank for the help
Old Aug 19, 2008 | 04:05 PM
fstphx's Avatar
3k- I wouldnt go any lower than that (a few people do though)
Old Aug 19, 2008 | 04:24 PM
87Lt1Monte's Avatar
wait on a real nice day and run.. you should go 9.99
Old Aug 19, 2008 | 04:27 PM
formulajunky's Avatar
I've heard don't go lower than 3k rpm..I assume its b/c of Cylinder pressure someone correct me if I'm wrong.
Old Aug 19, 2008 | 05:21 PM
87Lt1Monte's Avatar
i believe it is because there is a risk of bog at a low RPM.. If you bog ... u will have a problem.. you want to make sure your reving before activation...
