ATTN: MicroEDGE users...
Old Sep 16, 2008 | 05:18 PM
  #61
SuperSlow02's Avatar
holy **** LS1s came with a tape player?....
Old Sep 16, 2008 | 06:06 PM
  #62
bad6as's Avatar
mines a 98, dut it does have a 12 disk cd changer in the back.
update. got my bottle filled to check for leaks, no leaks found. also tested teh purge with the n20 in the line. had to aim it slightly, didnt want it hiting my hood. Tomorrow its geting tuned, i gotta swap out my injectors for my 42# when i get to the shop. then shoot 100 at it, then 150
Old Sep 17, 2008 | 07:49 PM
  #63
bad6as's Avatar
back from the tuner. 100 shot only made 80 and the 150 only made 130 or so. ill get the exact numbers tomorrow. bottle was full, still has 4lbs in it now. bottle psi was between 900-1000. i know dyno numbers dont mean any thing but i would have liked to see the 100 pick up 100 and same with the 150. one thing i was thinking about on the way home was my ground. i have the purge and n20 noid wired togeather, and then one wire going to the ground by the battery. i also have a few other grounds going there too. mabye another think is the microedge battery voltage with the car running is only showing 13.9v shouldent it be 14.5
Old Sep 17, 2008 | 08:05 PM
  #64
Thinking the noid wasnt opening all the way?
Old Sep 17, 2008 | 08:13 PM
  #65
bad6as's Avatar
yea, also when i test them or listen to them the purge is way louder then the n20. i wonder is i overheated and messed up the n20 noid trying to hear it click and because it wasent as loud as the purge. and it was on for to long and i didnt think it was
Old Sep 17, 2008 | 09:33 PM
  #66
Im not sure how to check...
Old Sep 26, 2008 | 11:18 PM
  #67
dmoss69's Avatar
Default Mircroedge!
Hey fellas,
I ordered 2 microedges, and finally got one hooked up yesterday on a friends car.
We wired it up, set our windows and triggers, crossed fingers, and let it rip.
IT WORKED FLAWLESSLY!
Turned on during 2nd gear in the rpm window that we commanded it to, turned off at upper RPM settings that we punced in (to protect tranny), and pulled HARD!
I think we have another customer wanting to purchase one now, we'll keep yall up to date on the next installation.
THANKS HSW!!!
dm
Old Sep 28, 2008 | 05:28 PM
  #68
bad6as's Avatar
does any one have a wideband hooked up threw the microedge yet? i bought a plx kit w/o a gauge because the microedge can be use as a gauge (right?)
well any ways i have it all hooked up but when i select plx from the choices it shows my afr as 0. so i tried a couple others and it reads a a/f ratio, whats going on?
the wideband sensor is on the drivers side right after my collector.
power and ground are hooked up, when i unplug it it loses signal so i know there good
the wideband sensor is pluged up to the plx harness and teh harness is pluged in to the plx red box.
the orange wire off the microedge is on the WB spot on the analog on the red box.
any ideas?
Old Sep 28, 2008 | 05:38 PM
  #69
Is the wideband and microedge grounded together?
  #70
bad6as's Avatar
yea i think so
Old Sep 28, 2008 | 05:43 PM
  #71
thats the only thing I can think of. They are pretty specific about them being grounded at the same spot
Old Sep 28, 2008 | 06:29 PM
  #72
bad6as's Avatar
my grounds are like this.
Old Sep 28, 2008 | 06:40 PM
  #73
hmmm.....I have no clue, how much was the wideband without the gauge..im interested in a set up like that. I dont want to run a tripple pillar pod. Too ricey for me
Old Sep 28, 2008 | 06:41 PM
  #74
bad6as's Avatar
around 190
Old Sep 28, 2008 | 06:43 PM
  #75
thats not bad, I was looking at the AEM for 250 with a gauge.. Let me know if you get it lined out
Old Sep 28, 2008 | 06:44 PM
  #76
bad6as's Avatar
will do!
Old Sep 28, 2008 | 07:02 PM
  #77
Matt@HSW's Avatar
PM responded to.
Matt
any ideas?
Old Sep 28, 2008 | 07:12 PM
  #78
bad6as's Avatar
you got one back
Old Sep 28, 2008 | 10:29 PM
  #79
Matt@HSW's Avatar
You have another one.
Matt
you got one back
Old Sep 28, 2008 | 10:31 PM
  #80
Matt@HSW's Avatar
For anyone else using the PLX SM-AFR we'll have to do a profile for it, but the scaling is the same as the AEM gauge, so you can use that profile with the sm-afr.
Matt
