walbro 255 pump...warranty??
Old Sep 20, 2008 | 06:41 AM
dawiz's Avatar
Default walbro 255 pump...warranty??
well, everything is together but the damn fuel pump in my fuel cell is dead! once all the wiring was done we armed the system and no pump? checked voltage...yup,12 volts. disarmed, checked voltage...nope so the arm/disarm guage is working fine.
remove the pump from the cell, bench test...dead? check continuity? nothing!
hopefully it will get covered under warranty since its brand new.
i did learn a valuable lesson though. there is no way in hell the car will get sprayed without an electric fuel guage in the car so i know i have fuel pressure before i spray!!!
Old Sep 20, 2008 | 10:19 AM
myfast70's Avatar
A FPSS would probably be a good idea too!
Old Sep 20, 2008 | 05:54 PM
Dabeztz28's Avatar
I dont beleive walbro includes warraty, but good luck.
Old Sep 20, 2008 | 06:16 PM
Beer99C5's Avatar
The autometer gauge works great, easy to log in EFI Live as well.
Here is the sending unit and FPSS
I have deleted the FPSS because the Trick Performance Black gauage has a AFR based lean/rich cutoff window.
I was able to send in a bad racetronixs pump in and get a new one, of course I had fuel logs to prove it was bad.
Old Sep 20, 2008 | 06:27 PM
Johnnystock's Avatar
+1000000...it saved my engine 3-4 times...
Old Sep 21, 2008 | 09:34 AM
Old Geezer's Avatar
try a search.. Plenty of posts on the situation w/ Walbro pumps dying....
Old Sep 22, 2008 | 09:35 AM
Chris@NitroDaves
Guest
Posts: n/a
It is begining to look like that there might be a problem with some Walbro Pump these days. I was talking to one of our dealers that has gone through 4 in 3 cars in the last 2 months. Sorry to hear that the pump went bad.
-Chris
Old Sep 22, 2008 | 12:35 PM
Nitro Dave's Nitrous Outlet's Avatar
Yep,
Walboro ran into an issue which pushed some questionable pumps out. True that they do not offer a warrenty. However in the situation like yours its obvious that the pump was bad from the get go. We will take care of you..
Dave
Old Sep 22, 2008 | 01:59 PM
dawiz's Avatar
thanks guys!!! the pump went out today via usps priority mail.
wiz
