When nitrous goes wrong, Kabooom!!!
So...let me get this straight, I run a 150 shot on my basically stock car, that makes me stupid?
also if you will NEVER run nitrous, why are you looking in the Nitrous section..
Please dont call people stupid for using the starter nitrous hits, call them stupid for improperly setting up their kit and slap the shop around for not informing him to bring the revs up before layin down the pedal
Also, I wonder what would have happened if that hood was closed on that Ford and that explosion happen...Would it blow the hood right off? Either way that would suck...
I don't see why low rpm nitrous activation would be a problem? Maybe someone can enlighten me on this?
Edit: when I sprayed, I had my window switch kick on at 3k RPM.
Yeah, The Lexus V8 1uz-fe motor must have a different intake and flow design, because everyone I have known over the years with the same motor running nitrous has not blown their intake and I'm sure they also shoot from idle too with their automatic trannies.....
I have never been warned about the dangers of low rpm nitrous use... Unbelievable.. I will still shoot the nos from idle with this motor, i've been doing it for years and don't see a problem... This LS2 of mine, I guess I will have to change up things... Darn that sucks!!!
Interesting to know... Thanks..
the 2v gt's are really more prone to this than the 4v's are..
In the Toyota performance world nitrous is typically run at lower rpms... You will find this to be the case in the Supra TT 3jz-gte run dragsters.. Where as these 6 cylinder motors just don't have alot of bottom end power and torque especially when fitted with large turbo's.. So many run nitrous just to get the 2jz run car out of the blocks and until turbo's spool...
Yes, it makes clear sense that when a motor is introduced to nitrous at low rpms it would create alot of stress on the motors internals...
