HELP! Timing tuner and progressive controller
Old Oct 3, 2008 | 12:50 PM
99ccz28's Avatar
Default HELP! Timing tuner and progressive controller
I am using a timing tuner and now hooking up a progressive controller. Would I just hook up the controller like the directions say or do I need to tie into the timing tuner somewhere?
I have it hooked up like the directions say but my solenoids are not clicking. the nitrous solenoid makes a ticking noise and the fuel does nothing. Is something wrong?
Old Oct 3, 2008 | 01:30 PM
Nitro Dave's Nitrous Outlet's Avatar
What progressive controller are you using. Ill see if I have a diagram for you.. You will have to add in a relay for the timming tuner.
Dave
Old Oct 3, 2008 | 01:35 PM
99ccz28's Avatar
I have a dynotune controller. I was going to get one off you but they said you wouldn't have any for a couple weeks.
Old Oct 3, 2008 | 01:43 PM
I have a intire wall of progressive controllers and windowswitches. No out of stock here.
So I am guessing you have there windowswitch and the timming tuner? Not a progressive controller? Or do you have the turn **** style progressive that Trick makes for both of us?
Dave
Old Oct 3, 2008 | 01:46 PM
99ccz28's Avatar
I have the turn **** style. I called and was ready to order but was told you were out. I dunno, the guy I talked to wasn't very knowledgeble about it. But he did say your were out.
It was Monday when I called.
