Thanks for providing the tech!
Old Oct 10, 2008 | 01:00 PM
dirthead racing's Avatar
Default Thanks for providing the tech!
I signed up to figure out if I could run my fuel and N2O noids seperately with my FJO mini......you guys already had it taken car of, I just needed to change some of my keyword in my search. I see the 18:1 lean spike for less than a second but it's enough for my car to get pissed and pull 9 deg of timing. I'll be running the fuel off stage 1 and the N2O on stage 2 with a delay. Any input on where I should start with the delay? I'm running NX Iceman noids with a 100 shot wet on my SC 3800. Might be enough to get me into the elusive 11's. Again, thanks guys for providing the tech!
Old Oct 10, 2008 | 01:28 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
look at how long the lean spike is, then start adjusting the nitrous activation in 100 RPM increments.....by running the solenoids on seperate stages you can also change the ramp rates for each to stabilize the A/F ratio
Old Oct 10, 2008 | 02:21 PM
I'll try that. Thanks.
