Northwest Members WA, OR, ID, MT, WY, SD, ND
car is running
Old Feb 11, 2011 | 07:49 PM
02sslayer's Avatar
Default car is running
got the intake installed and the car is running. it runs kinda shitty down low, doesnt wana idle, slow throttle response lots of surging and bucking. i hope its in the tune, i would hate for it to be a vacume leak
Old Feb 11, 2011 | 08:16 PM
Mikey 97Z M6's Avatar
What all did you do to it?
Mike
Old Feb 11, 2011 | 09:26 PM
freefallen.1's Avatar
Nice Joe. With any luck it will be the tune and not a vacum or worse>>
Old Feb 11, 2011 | 09:30 PM
tmoney223's Avatar
Yeah that would suck! Hope it's just a tune. Is that the one you bought from Todd?
Old Feb 11, 2011 | 10:10 PM
*02WS6TURK*'s Avatar
Yeah he bought the FAST 90 and the NW 90mm TB from me. The Fast had a couple smack cracks in it. Wong thought they could be fixed easily. I didn't want to mess with it so Joe got a killer deal on it. Hopefully it works out okay Joe. The previous one I sold to Poncho ran just fine after he put it on...w/o a tune as well. Did you use some JB Weld on the areas needed?
Old Feb 11, 2011 | 10:37 PM
Duct tape and bubble gum FTW
Old Feb 11, 2011 | 11:15 PM
Big League Chew
Old Feb 11, 2011 | 11:18 PM
ls1whip's Avatar
hahhaaahahahhah diiiiiaamm..... hey spary alittle carb cleen around the intake and see if it picks up some revs.. most likley its prollly running bad cause the tune and your computer is set on your old tps settings and iac specs..
Old Feb 12, 2011 | 01:48 AM
02sslayer's Avatar
Mike
fast 90/90, still using the slp lid and stock maf. it needs a lil adjustment on the tb also, there is a little slack in the cable so im sure thats why i have the shitty throttle response. but at about 3500 rpm it scream pretty good, i couldnt get any traction tho. i think its the tune
ya but his motor is a 408 that might be a reason.
Old Feb 12, 2011 | 06:27 PM
Oh I gotchya. I didn't know you bought that intake from Todd.
Mike
Old Feb 12, 2011 | 07:30 PM
smokinponcho73's Avatar
Hey adjust the idle screw. I did and mine worked just fine.
Old Feb 12, 2011 | 07:32 PM
02sslayer's Avatar
ya i will lol. something else i noticed is that the little idle hole in the tb blade is a lil smaller maybe than on a stock tb?
Old Feb 12, 2011 | 07:38 PM
That'll work temporarily, but if you open it too far you'll start messing with the PCM's fuel trims in the tune.
Mike
Old Feb 12, 2011 | 07:44 PM
02sslayer's Avatar
Mike
i really hope there isnt an issue, cuz i do not wana take that thing off again.
Old Feb 12, 2011 | 08:23 PM
SalvageZ28's Avatar
Yeah but thats the chance you take working with Salvage parts=)
Old Feb 13, 2011 | 01:05 AM
02sslayer's Avatar
lol, you know all about that dont you
Old Feb 13, 2011 | 04:34 AM
Mike
Do you think it will mess with the PCM to much? I just did mine so it will idle at like 850 instead of 600.
Old Feb 13, 2011 | 04:52 AM
SalvageZ28's Avatar
Fixing cars is all about making things work man=)
Old Feb 13, 2011 | 10:44 AM
Plus it's not the size of the intake that matters, it's the motion of the ocean.
Old Feb 13, 2011 | 11:34 AM
It could. I can't remember the percentage off the top of my head, but I think if the throttle position is registering more than 2-3% open at idle (ie: adjusting the idle screw to open the blade) it will start to affect the short term and long term fuel trims because it's no longer using the idle tables at idle.
Mike
