Help: sick wit it / local help
I'm aboput to shoot this thing, I'm a amn of patience, but these cars are getting increasingly silly for my understanding. Lifes too short, might sell it and get my 78 back. Chris http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
See if that can unlock the stereo. Somewhere there is a way to turn it off. If you have the owner's manual still I know it is written out in there or possibly look in the audio section of the forum, I'm sure someone has gone through it there.
As for the lights, sure there isn't a part way open door or the dimmer didn't didn't get by a knee on accident and force it to keep the lights on? Been there done that myself
. Unless this is an aftermarket alarm it could have an issue that is causing the lights to stay on, but typically they are set for a time delay dim -> off. The time delay seems way out of line, it takes 15 to 20 minutes to go off after arming the system, and the same delay after the car is running. When I innitially reset the system the rear hatch was slightly popped and I didn't know it. I believe that was the source of failure. I combed the threads and got fed up with the time consumption since I work and take courses fulltime. I might just give up due to time and let the "stealership" take my money.
