Northwest Members WA, OR, ID, MT, WY, SD, ND
Codes i need to FIX...HELP!
Old Apr 27, 2014 | 10:49 PM
FAD2BLK93's Avatar
Default Codes i need to FIX...HELP!
Ok guys need some help. Got 2 codes i need help with B0026, driver frontal deployment loop open and U1040 loss of comunication with ABS. I believe the codes are related to each other. I have changed out the ABS block from another 2000 camaro SS, still the same code. I have power and ground to the connector. Can someone show me a pinout to the block to the PCM please? Where do i start to restore communication? I tried to scan it and it could not connect, i had to go thru the airbag code to find the ABS code. I have many lights on the dash lit...ABS INOP, brake light, service vehicle lite, airbag light. Thanks Marc
Old Apr 27, 2014 | 10:59 PM
Mikey 97Z M6's Avatar
First thing I would do is check all the grounds in the engine bay. A loose ground will light up a dash like a Christmas tree.
Any decent manual should have electrical schematics for tracing out lines. You might be able to find specific pinouts with a Google search.
Mike
Old Apr 27, 2014 | 11:26 PM
FAD2BLK93's Avatar
I have check the grounds and power at the block they are good. I believe the PCM is not receiving the info. I will check further. Thanks Marc
