Plastic infront of radiator?
But I'm looking at this for open road racing. Figuring I could cut out the area behind the lic plate cover to let more air in. And with 2 tranny coolers in front of the AC condensor, I will need air. Bill, Boyce, Ellis?
Until your ready to do that, I wouldnt mess with anything
Leaving it is the way to go. Even if you convert it to a front feeder like the New Vette or Boyce you still need it to get the air to go Through the radiator and not Around it
I, however did run without some of the plastic for quite a while. I saw no ill effects. But prior to the pe130 everything was back in place for the exact reason Ellis mentioned.
Funny you should mention heat extractors Bill. I was out there staring at the car thinking the best solution might be that Meecham (sp?) hood. Guess I'll just hang my tranny cooler & figure out what radiator to put in it now....
