Northwest Members WA, OR, ID, MT, WY, SD, ND
Drive Shaft Removal
Old Feb 8, 2005 | 03:45 PM
99LSS1's Avatar
Default Drive Shaft Removal
Well it does not seem that I will be able to get the driveshaft loop in without removing the driveshaft. I haven't done thais in a long time so I need some instructions. It looks like there are 4 bolts in the rear. Do I remove these to get the shaft out?
Old Feb 8, 2005 | 04:01 PM
WAHUSKER's Avatar
Yes. take those off & it should pop right off the rear end (you may need to persuade it with a big screwdriver). You usually need to do 2 bolts, then rotate the DS to get the other 2 because of the torque arm blocking access.
To make sure it fits I lower the end of the DS & slide the loop on & set the DS back in the rear end & then position the loop. If it fits, then I bolt the DS back up.
Old Feb 8, 2005 | 04:14 PM
HitmanLSX's Avatar
Do you wanna mark it at all to make sure it goes back on the same and isn't rotated?
Old Feb 8, 2005 | 04:27 PM
WAHUSKER's Avatar
Doesn't matter.....while the DS is balanced, the pinion yoke is not.
Old Feb 8, 2005 | 05:19 PM
Poik's Avatar
And they are 11mm bolts FYI. Big screwdriver was a must for me when I did this Sunday.
Old Feb 8, 2005 | 06:42 PM
99LSS1's Avatar
Thanks guys, got the DSL installed. My driveshaft came out pretty easily. and NO!!! I did not polish it when it was out. I do draw the line at some point.
Old Feb 8, 2005 | 06:47 PM
Tranzor's Avatar
Just don't polish anyone elses driveshaft and you're golden...
