Two quick questions about cam
2) Does it affect the idle and if so what to expect?
Example Futral F-5: 224"/228" .588"/.576 (114 LSA)
Thanks
And that cam has as much lift as I would consider on a stock setup. 588 is a ton. I would highly suggest new roller rocker arms & chromoly pushrods. And if you are going to run that under John B's heads, ask him to clay the motor to make sure the valves clear the pistons. As I recall those heads have been milled. Meaning you get more compression, but you have to worry about clearance when you run a hi lift cam. And this one's getting up there.
PS If you are going to have John put this together, I'd ask him for a cam suggestion, since he knows how those heades perform.
I am salivating on that F-5-114 but I may have to rethink that. I'll have to bug John again...
BTW I'm ordering the QTP headers and Y-pipe this week YAY!!!
I wanted a cam with a bad-*** idle, and knew that meant it would be 'fun' to tune. And I wanted one that didn't have ramp rates that were too agressive (easy on the valve springs). I also wanted good mid range torque & fair top end hp. So I ended up with a GM Hot Cam & added 1.8 Harlan Sharp Rocker Arms to get me to the .555 lift I wanted.
I suggest anyone that doesn't know exactly what they want, do some research so you have some basic understanding of what things do. Then pick a reputable guy (like John or Ellis or Ryan or ____) to help you build your motor & just do what he says. Because if you start doing half of what one guys says, and half what some other guys says, it AINT gonna work. Most of us have a system / plan / grand design. And you need ALL the parts to make it work.
And no, I am not flipping you **** for asking these questions. Knowledge is good. But I am saying if you're going to let John do it with his heads, let him pick the cam. He knows his **** & has made good power with those heads.
And you will LOVE those headers!
Definitely tap the knowledge we have floating around this area, and you picked a great guy to consult with in John B.Cams are definitely like women... pick the right one, you'll be in heaven. Pick the wrong one, and well... lets just say you ain't gonna be a happy camper. I picked my cam because I wanted something that:
A) would provide good power in the upper rpms for drag racing without overpowering the car on the street in the low rpms,
B) wanted a big nasty sounding cam that had slower ramp rates so it would be easier on the valvetrain,
C) wanted something with plenty of lift for when I decide to go with some nice high flowing heads, and
D) was a split duration in case I wanted to run a decent shot of nitrous
A good idea is to make a list of all the things you want out of your car mods, what the most important features you like in a cammed car, and go from there. Make sure you pick a cam that you will not only be happy with now, but will also be a good match for any future mods.
Mark, I agree with you. Although I do ask lots of questions I at the same time have a huge respect for all the guys who have "been there, done that, got the t-shirt" -- yes, that includes you -- so thanks again guys for all the info, that really helps on getting my homework done.
I'll wait and see what John has to say - either way I think the car is going to turn out awesome.
MTI S2-R + cam + QTP + tune
Ask Brian Smith. that is where it came from
For my next project we picked a custom cam from cam motion. Just a baby Hydraulic Roller 240/247 with .600ish lift
I think that a custom cam is defenatly the way to go, you just need to know exactly what your heads flow, what size valves, what comp ratio, how much your car weighs with you in it, what gears you have, and what your goals are.
One more thing and this is just my opinion. If you want a good racing cam, it's not going to be a nice street cam, and the same goes for a street cam, trying to race. Its real hard to get a cam that does both really well, so just make shure you know what you want to do with the car and stick with it.
