Paging Ellis - Urgent
Let me give you some numbers so you can tell me if I can go with this combo
or if I need to go for a smaller cam, or if gaskets will solve the prob.
HEADS:
TEA 5.3 stage 1.5
- CNC Port LS1 5.3 Head to Stage 1.5
- 3.900” Combustion Chamber
- Blend Valve Job
- Mill Heads to Customer Specs (NO MILLING FOR ME)
- Flow Intake and Exhaust Ports
- Heads Cleaned, Set Spring Heights, Assemble, Seat Pressure, Installed Height, and Coil Bind
- Ferrea 2.020 Intake Valve
- Stock LS1 1.550 Exhaust Valve (REV 1.57” Exhaust Valves are also available)
- Standard TEA .650" Lift Dual Spring” (Comp 1.250” 921 and Comp 1.440” 978 are also available)
- TEA Titanium Retainer
- TEA Locators
- GM Locks
- GM Intake and Exhaust Valve Seals
CAM:
F13 = 230"/232" .595"/.585" 112LSA (+4)
or
F13 = 230"/230" .595"/.595" 114LSA (+4)
Ellis if you can shed some light on the cam here I would appreciate it. I'm leaning towards the 114lsa +4
Most important -> pv clearance, can you tell by looking at those numbers if it will be ok?
THANKS ELLIS!!
Nate
Hehehe Thanks Mark
Nothing like tunning with a 10Kpa range
