Northwest Members WA, OR, ID, MT, WY, SD, ND
Gague Cluster Problems
Old May 30, 2005 | 12:58 AM
MrPongoSS's Avatar
Default Gague Cluster Problems
I was driving my '99 Camaro SS today and all of a sudden the speedo and tach started going haywire and all the warning lamps went on. It did that for like 5 seconds and then it reset itself and everything was normal, other than the trip odometer reset itself back to zero. I pulled over and check the battery cable, etc. but all seemed normal. I have never seen that happen before in any camaro that I have owned. Anyone know what might be the problem?
Old May 30, 2005 | 01:02 AM
Matto ELITE's Avatar
This is a problem that generally isn't vehicle specific...A loose ground often causes this, 1 that all the body control modules and Instrument Cluster coorespond to.
We had had this problem on a 03 Cobra; we turned the key over, and the tach and speedo went haywire, along with all of the warning lamps and indicators lighting up. After tracing through a wiring diagram, all of these siganls shared a common ground, which was under the passenger side kick panel. We pulled the molding and carpet back to reveal that the ground was slightly loose. We "wiggle-tested" the suspect ground, and the problem replicated itself.
This might neccessarily be the problem, just food for thought.
Old May 30, 2005 | 01:11 AM
MrPongoSS's Avatar
Sounds reasonable to me... thanks for the input!
Old May 30, 2005 | 08:57 PM
kickassT/A's Avatar
check your battery before you dive too far into the electrical system. i had the same thing happen to me when i had my camaro. the positive bolt is just a ch too long on some cars, and punches through the lead of the terminal, letting acid leak out and eat up the cable. i cleaned up my cable and put in a new battery, and never had any more problems out of the car.
Old Jun 5, 2005 | 08:02 PM
MrPongoSS's Avatar
Thanks for all the advice. The SS is going into the shop on Monday, though, and not just for that. I ran the engine a bit this AM to circulate some fluids, and low and behold... a nice little river of coolant came out from underneath to car. So, it is going in for a new water pump too. Well, it is getting up there in miles, so it was bound to happen sooner or later.
Old Jun 5, 2005 | 08:12 PM
madhatter's Avatar
Also check the alternator. I have had a few cars do that when the alternator was about to go.
Old Jun 6, 2005 | 01:05 AM
MrPongoSS's Avatar
I wouldn't doubt it. It is at that time in miles that everything is starting to go...
QUOTE=madhatter]Also check the alternator. I have had a few cars do that when the alternator was about to go.[/QUOTE]
Old Jun 6, 2005 | 05:15 PM
MrPongoSS's Avatar
I'm glad I took it in... found a few other things that needed to be fixed. The SS might be out for a while, but we'll see.... all I know it that the nickel and diming is gotta stop sometime...
[/QUOTE]
