ET streets question/ need help
I'm still spinning the MT drag radials @ 14 psi, please help.
I ran the T/A 14 times last sunday and 12 times the week before. The MT drag radials are looking pretty beat up already and I have like 800 miles on them.
ET Streets hook HARD for me... they hold anything I can throw at 'em, even the 6k+ clutch dumps.
Now, your radials should hold... I think a big problem is track prep probably sucks out at Monroe which doesn't help. Also, you gotta make sure you heat em up... I mean BIG smoke show for a radial. And if that don't work, try lowering the psi to 13 psi cold and see what that does. They should be holding for you...
Last weekend my best was 7.57 which is not good enough to run in bracket 4. There's a few cars that run 7.52 in my bracket. For some reason I have not been able to match my personal best from last season.That's why I'm dissapointed. The T/A is running strong though, just not quite where I want to be. Hooking up is the key.
Eddie
