Northwest Members WA, OR, ID, MT, WY, SD, ND
Antifreeze level drops
Old Jun 8, 2006 | 10:50 AM
Ackattack1's Avatar
Default Antifreeze level drops
This is in my pickup.
I keep running low on antifreeze. I keep toping it off, thinking maybe its working air out (put a "new" radiator in not too long ago). Anyways, after running it to full operating temp while filling, continuing to run, etc. and topping it off, its still loosing antifreeze. It's not leaking any outside of the engine that I can see. No drops anywhere.
So that leaves with me two options I can see. 1 is the tranny cooler (inside radiator) is leaking antifreeze into the tranny, but I would think I would be seeing tranny fluid in the radiator as well, so I don't think this is it. The other option is head gasket leaking, and its going into the oil pan. The thing is I can't see any symptoms of this. No overheating or ill effects.
Anything else I'm overlooking.
I was thinking I'd do a compression check to see if that revealed anything. What else can I check?
Thanks
Derek
Old Jun 8, 2006 | 11:07 AM
Rokko's Avatar
Tech Addict
got white exhaust coming out from either bank? check your plugs too. headgasket problem? did you overheat it at any point that you remember?
I woiuld think you'd see in the tranny fluid on the dipstick if it's leaking into the tranny cooler part of the radiator.
Old Jun 8, 2006 | 11:30 AM
Ackattack1's Avatar
No white smoke. Never over heated since I've had this engine (put it in last year)
Old Jun 8, 2006 | 11:45 AM
Poik's Avatar
Does your oil look like mocha?
Old Jun 8, 2006 | 12:18 PM
Layn_Low_247's Avatar
I'd say head gasket.
Old Jun 8, 2006 | 01:39 PM
WAHUSKER's Avatar
Do a compr test, and a pressure check on the radiator too. If either one bleeds down or is low, you have found your problem. Milky oil or tranny fluid is one symptom. Tranny fluid or oil in the radiator or overflow tank is another. You can be burning a little antifreeze & not have white clouds of smoke. But it should show up on a compr test. And as Rick said, check the plugs. If one / more looks browner or greener than the rest, that is your cylinder.
Quite often it will be your water pump leaking out the back (drain hole that indicates the bearings & seals are gone) and you won't notice it until you pressurize the radiator & then the water will start dripping down the front of the motor. Same with a pin-hole in a hose. It vaporizes while driving so you don't see it.....
