Some questions...nitrous advice..?
To answer some of your nitrous questions..........the car could more than handle 100hp shot of nitrous. I would go with a dry kit due to the ease of installation and what not! Also I would go with a window switch and WOT switch. With those you should be able to run 150shot with no problems.........but a 100hp shot will work well too.
You mark my words................and anyone here who sprays nitrous on there car can confirm or deny (which they won't), once you start spraying you will only want more. Its like a drug, its so easy to up the jets and spray just a bit more. You say now, "I won't want to risk blowing my motor or blah blah blah".........if you put nitrous on your car, you'll see what I'm talking about.
Have fun and you will need a new 12bolt rear end if you get some spray.
Well you got the next 4 months or so till Feb when the track opens back up.
However if yours schedule permits and weather is cooperative, there is 2 more TnT's October 20-21.
I'm hoping to have my cage finished in time to hit those and maybe the bracket race at PR on the 15th.
Robert
