Northwest Members WA, OR, ID, MT, WY, SD, ND
T/A headlight motor?
Old Nov 15, 2006 | 10:56 PM
Rottluver's Avatar
Default T/A headlight motor?
Anyone have a spare driver's side headlight motor laying around for a 2002 (or 98-02) Firebird by chance? Mine crapped out this last weekend and is making that hideous noise.
Any help would be greatly appreciated. Even just a part number or a place to get it fairly cheaply if you don't have the part itself.
Old Nov 15, 2006 | 11:05 PM
CHarris's Avatar
Is it the motor or the gear? As I recall, there is a gear flip mod that applies to your headlights.
Old Nov 15, 2006 | 11:10 PM
Rottluver's Avatar
Not positive, all I know is that anytime I turn on or of the lights or use the remote to lock/unlock the car, the headlights go up & then down and then I get a horrendous noise for about 5-10 seconds.......happened on my 95 TA but it was under warranty so I had nothing to do but drive it to the service dept and let them deal with it.
I am doing some reading but the search function on this site is down for some reason.
Old Nov 15, 2006 | 11:12 PM
LSxChevelle's Avatar
Search in the Firebird/Trans Am section otherwise buy the metal replacement gears.
Old Nov 15, 2006 | 11:15 PM
Brad's did that too... He got his parts from Fred Beans but he needed more since some brackets were also broke.
Old Nov 15, 2006 | 11:23 PM
Rottluver's Avatar
Tried search but apparently it is non-op right now. Saw LOTS of threads about the SEARCH feature not working right now..........and I am getting rid of the car so I wanna fix it for as little as possible.
I will try FB cuz GM Parts Direct wants $165 each!!
Old Nov 16, 2006 | 01:55 PM
B-RAD2's Avatar
Sorry i'm just now getting to this but here is the link to where i orderd the gear from: http://www.bfranker.badz28.com/headlightfix/index.htm
i got it in a few days. it works great and won't strip again. it took me about 30 to 45 min to replace the gear in the motor.
there is a temp fix on that link. you can rotatethe current gear cause the notor only uses half of the gear. it's all on the link
Brad
