Northwest Members WA, OR, ID, MT, WY, SD, ND
Bad O2 sensor heater code
Old Feb 22, 2007 | 11:41 AM
Rokko's Avatar
Tech Addict
Default Bad O2 sensor heater code
I'm getting that right now, I have the 2 post cat converter stockers in my garage, can I use one of those to get by until I can get the good Denso's to replace them with?
Old Feb 22, 2007 | 11:58 AM
Ryan'sSS's Avatar
I believe the rears are non heated.
Old Feb 23, 2007 | 11:28 AM
Rokko's Avatar
Tech Addict
A lot of the sites listed the fronts and rears as the same part number.
Replaced em both and my fuel filter last night after work. Runs like a champ again. I was getting what felt like tranny slippage in 2nd gear during WOT but it was either running out of fuel due to a clogged filter or the O2 sensor not working correct.
Old Feb 23, 2007 | 01:01 PM
TwoFast4Lv's Avatar
they are heated.
Turn the code off
Old Feb 23, 2007 | 01:05 PM
Rokko's Avatar
Tech Addict
I have the rear codes turned off, but I want to know when the fronts are acting up or failing.
Old Feb 23, 2007 | 01:15 PM
TwoFast4Lv's Avatar
Well Mine toss's that code non-stop no matter what sensors are in it. the main reason is they do not respond as fast as the computer thinks they should so the PCM assumes they are failing and sets the code...they are just the heaters man turn them off
Old Feb 23, 2007 | 03:23 PM
Rokko's Avatar
Tech Addict
Ahhh, I see says the blind man. The sensor was actually toast, it was black and not responding. I got no response out of it according to my predator handheld.
Since swapping them out I haven't got the code again. I haven't had to do much tuning to my car yet. If I disable that code is there another one that will let me know if the O2 sensor fails?
