Northwest Members WA, OR, ID, MT, WY, SD, ND
Proforma School
Old Mar 22, 2007 | 07:20 PM
WAHUSKER's Avatar
Default Proforma School
I got my confirmation in the mail today. Damn, I'm getting the itch to drive my car, I can't wait to try her out in the turns! Sure hope this crappy weather clears up.
Sadly I have been spenidng all my time & money on getting the car to run right after the car show, so the new suspension won't be on the car.
Maybe I'll just HAVE to go back for another session.
Old Mar 22, 2007 | 10:43 PM
howierd42's Avatar
Got mine today too. They want a check for 2500 (returnable) in case I destroy the school car. That should bounce to the moon. It isn't enough that they are taking an extra 300 to use their car but now they want a dammage deposit too. There goes all the fun of using their car .
Old Mar 22, 2007 | 11:54 PM
WAHUSKER's Avatar
Maybe they've seen you drive?
Sorry, I couldn't resist....must have been that Robin Williams movie I just watched.
Old Mar 23, 2007 | 02:24 AM
Crisisman's Avatar
It'll be great to see you all there. Only 18 days to go!
I've got to get my car checked out though. At the dyno day I noticed my exhaust seemed to be hanging lower than the other GTOs and yesterday I walked up to my car to find the tailpipes sagging. I looked and found the rear hangars had completely slipped off!!! I don't have a lift, but I need to get under there and make sure the exhaust is secured everywhere it is supposed to be. I'd hate to end up dragging my mufflers around the track!!!
Old Mar 23, 2007 | 06:26 AM
KrautBurner's Avatar
mine came in today too,
but I'm planning on running a Lotus,
the paperwork has me using my car (which isn't exactly up to the task yet)
Old Mar 23, 2007 | 09:14 AM
howierd42's Avatar
I probably deserved that, Mark.
And I would have loved to use the Lotus too, but I just could not bring myself to shell out 300 more dollars for the upgrade.
Old Mar 23, 2007 | 11:51 AM
"it's only money,
what are you gonna do? ... spend it on something you want..."
I figure my car isn't quite up to the task right this second (but will be this season)
and driving a F/F car (Cavilear / cobalt) won't do a whole lot for me.
and,
how often do you get to rail on a Lotus for a test drive on the track?
Old Mar 23, 2007 | 03:11 PM
vtec this's Avatar
I haven't checked the mail yet, but I am getting REALLY excited as well. I have a few more things I need to do to my car before then, but I can't wait!
Old Mar 23, 2007 | 03:13 PM
vtec this's Avatar
Mark, what were you planning on changing in your suspension setup?
Old Mar 23, 2007 | 05:03 PM
Tranzor's Avatar
I'm also signed up for the April 10th class... just don't completely blow the doors off my poor slow little L98.
Old Mar 24, 2007 | 12:24 AM
howierd42's Avatar
Don't worry, Jason. I will be in the slow little track car. Everyone and their brother will be passing my slow a$$.
Old Mar 24, 2007 | 10:05 AM
WAHUSKER's Avatar
I plan to put dbl adj HALs with their springs up front, and their coil over adj on the rear. I need to decide which spring rate to run (& get some money).
Old Mar 24, 2007 | 03:18 PM
vtec this's Avatar
What money!!? Since when has money been a factor?
Old Mar 24, 2007 | 07:47 PM
Poik's Avatar
As in HAL drag race shocks and springs..?
Old Mar 24, 2007 | 09:15 PM
Tranzor's Avatar
HAL shocks can be used for the whole spectrum, not just drag racing. And I do believe they make a road racing spring, so I'm guessing that's what Mark's talking about.
I can't see him taking corners with HAL's 275lbs drag racing springs up front.
Old Mar 26, 2007 | 11:49 PM
ram-it's Avatar
There won't be too much passing going on for you school boys! Jason, that C4 is probably one of the better handling cars out of the group and that lowly L98 has some grunt to come out of the corners with. It just going to kill you going down the straights.
Old Mar 27, 2007 | 07:28 AM
WAHUSKER's Avatar
You are correct Jason, HAL makes several different spring rates for their front & new coil-over rear setups. I'm thinking their heaviest ones are what I'd want. Just need to make the call. (my car bottoms out now, so I need stiffer springs)
I would sacrifice some of my drag racing performance with stiffer front springs. But the adjustable HALs should let me set the car up to do everything fairly well. Like taking bumps at speed without losing my exhaust. I definitely need dbls up front now for drag racing.
Old Mar 27, 2007 | 01:44 PM
Tranzor's Avatar
So Eric... where do you go to get your brakes checked out? I want to make sure mine are good to go for the driving school.
Old Mar 27, 2007 | 02:11 PM
Rokko's Avatar
Tech Addict
You all going on the same day? What day? I"ll try and get that day off and come down to watch and video tape if any body needs me to.
Old Mar 27, 2007 | 02:52 PM
NataSS Inc's Avatar
650lb front / 225 rear
Big front sway and stock rear sway. Car should move smooth as butter.
